MEINE KAFFEEMASCHINE: Siemens TK76F09/01
hello
my eq7 stopped pouring water and coffee. i replaced the brewery unit and and bought a set of gaskets and replaced them. all the water is in the tray and nothing comes through. the ceramic valve is cleaned. In test mode the water pump shows a normal 50ml, but the water is always in the tray. what could it be
MEINE KAFFEEMASCHINE: Siemens EQ8 300
Maybe the gasket from ceramic valve to brewery unit is not installet.
Are all hose in the right position on ceramic valve?
Yes i think they are in right position. Is it posible that the pump doesnt provide enough pressure? There are some air boubles in big white hose
Which gaskets did you change? was there a leak before chanching gaskets? The white hose bubbles are normal.
12.04.2022, 08:49
(Dieser Beitrag wurde zuletzt bearbeitet: 12.04.2022, 08:53 von darjanbarle.)
I changed all gasket on hose( xxxl repair kit)
Something new .... I disconnected the red hose from the pump and the water is flowing normally from the pump. Maybe the heater is clogged? How do I clean it if the water doesn't go there?
The heater is mounted with two screws. it is sufficient to open the upper screw which is mounet on brewery unit side, then you are able to pull the top of the heater. maybe there is lime inside. after mounting discale.
I have another question .. today I noticed again that when cooking a cappuccino cup is not as full as it should be. again water escapes through the white pipe into expansion. It works ok when preparing hot water and it is also very hot water. is it possible that the pump is already poor and not creating enough pressure?
14.04.2022, 11:43
(Dieser Beitrag wurde zuletzt bearbeitet: 14.04.2022, 11:44 von swolle.)
White Pipe is an Over Presure Pipe, i think you should discale with seomething on Amidosulfon basic.
Yes, i already ordered descaler with amidosulfon basic. Thanks for now
